missing power jack
NordicTrack Audiostrider 800. I want to use an AC adapter. On the rear or the console, there is a location that is labeled 6 volt regulated, but there is not a jack in the hole in the console to plug anything into, just a empty hole. Need some advice for this. I know I can purchase the AC adapter, but what about the part that goes in the console to plug the AC adapter into?
12. The Console (4) requires four D batteries (not included); alkaline batteries are recommended. Do not use old and new batteries together or alkaline, standard, and rechargeable batter- ies together. IMPORTANT: If the Console has been exposed to cold temperatures, allow it to warm to room temperature before insert- ing batteries. Otherwise, you may damage the console displays or other electronic components.
Remove the screws and the battery cover from the back of the Console (4), insert batteries into the battery compartment, and then reattach the battery cover. Make sure to orient the batteries as shown by the diagrams inside the battery compartment.
To purchase an optional power adapter, call the telephone number on the cover of this manual. To avoid damaging the console, use only a manufacturer-supplied regulated power adapter. Plug one end of the power adapter into the receptacle inside the battery compartment on the console and route the power adapter through the notch in the bat- tery cover; plug the other end into an outlet installed in accordance with all local codes and ordinances.
