Error 425 on a Pacemaster Gold Elite
Hi,
After not using our treadmill for months, we immediately got an error 425 before the thing even started to move.
I verified the fuse. It is good. Bought a new one just in case. Tried it after unplugging the treadmill for a minute. Same problem.
The resettable breaker near the cable bulkhead is not tripped.
I noticed however that the electrical cable was pinched in the inclination mechanism. I had to disassemble the wormgear pins to release it. The cable was pretty flat with a thickness of about 1/8” while it should be at a diameter of 5/16”. I removed the exterior protection of the cable at the flat area, over about one inch long. The wire insulation’s were intact. No signs of shortage though the wires were quite flat of course. I use a pair of plier to give them back their normal round shape. Tried the treadmill again without any changes. Error 425. Could it still be damaged enough to trigger Error 425 while being good enough to supply power to the electronic board?
Any idea what I should do next? The maintenance guide doesn’t seem very helpful at this point...
Try this:
https://www.treadmilldoctor.com/dc-amp-draw
then try:
https://www.treadmilldoctor.com/motor-testing
Great job on narrowing down the issue!
Much appreciated!
An analog detection circuit indicated that the voltage across the power FET stayed low.
1. replace lower board
2. replace motor
The lower board is no longer available.
Can those lower boards be repaired?
Are there any procedures to test those?
Thank you for your help.
Pierre
https://fitnesselectronicrepairs.com
954-578-0900
if you tested the motor and that runs with a battery , then lower board is bad.
What is your model number so I can get you the correct part number?
The motor model number: S3480B3291
Once you've added items to your Cart, and you are ready to Check out and you put all your shipping info in, you then can put this Discount Code ( 1982 ) in the Discount Box on the Check out Page where you put in your Billing and Shipping information. You will see your Discount Amount Applied which is 5% on the right side of page.
Thank you for your help in troubleshooting the issue.
