Pacemaster Pro-Plus ELEVATION ERROR
                    Treadmill works fine except for incline.  Actual elevation is stuck at 0 but the display shows it to be 15.0.  If I press the down Elevation button after the treadmill starts or bring it down to 0 before it starts, the elevation motor jerks for a split second and then the entire unit shuts off.   The error code is ELE ERR and the elevation display goes back to 15.  Any idea how to fix this?
Look at section 2-12 to 2-14
I also pulled out the incline motor. I then reattached the motor's wires to test it with no resistance. The threaded shaft did spin for a second but then it shut off and I got the ELE ERROR. The part that the shafts spins into to raise and lower the treadmill was at maximum extension as if the treadmill had bottomed out at 0 degress. Does this sound like it's the motor or power supply that needs to be replaced?
