Smooth Fitness 6.25 power problem?
(This is an edited post, as I inaccurately described the problem).
My Smooth Fitness 6.25 treadmill briefly shows 'Err2' on start. I couldn't find a root cause for this error when googling.
I'm guessing its related to a new behavior where power to the motor seems weak. The belt does not move as fast as it used to and slows when stepped on. The motor also is making a new whirring noise when running, and clicking noises when I move the belt by hand.
All the console LEDs are working fine.
Is there a way to tell if its an issue with the transformer or the power control board? I dont have a wiring diagram for the unit.
And I've not done the Amp test yet as I need to get a multimeter.
TIA
TIA
