Smooth Fitness 6.25 power problem?
edited February 7 in Treadmill Problems
(This is an edited post, as I inaccurately described the problem).
My Smooth Fitness 6.25 treadmill briefly shows 'Err2' on start. I couldn't find a root cause for this error when googling.
I'm guessing its related to a new behavior where power to the motor seems weak. The belt does not move as fast as it used to and slows when stepped on. The motor also is making a new whirring noise when running, and clicking noises when I move the belt by hand.
All the console LEDs are working fine.
Is there a way to tell if its an issue with the transformer or the power control board? I dont have a wiring diagram for the unit.
And I've not done the Amp test yet as I need to get a multimeter.
TIA
  • sounds like more than 1 issue here. Motor and motor controller. your only option with the motor is to have it rebuilt. I do have the motor controllers. you might find a used motor at fitnessgraveyard.com
  • Thanks. How much is a controller?
  • they are 299.99 you can order 1 by calling me at 888-362-1105 x 330
