NordicTrack Commercial 1500 starts then stops after 2 seconds
                    Model# NTL09707.1.  Serial# V54132146.  Treadmill is older but worked great up until yesterday!  I start it on manual and the belt runs for 1-2 seconds, then stops.  I turn it off, try it again and same happens.
Trying to determine if it's worth it to try to repair or just buy a new one. Thanks!
https://www.treadmilldoctor.com/nordic-track-commercial-1500-model-ntl097071-motor-control-board
Once you've added items to your Cart, and you are ready to Check out and you put all your shipping info in. Use this code 1982 at checkout for a 5% discount on your order.
Except there's a high pitched squeal coming from the console. How do I get it to stop?
