burning smell from proform 300i motor
Hi, I have a proform 300i that I regularly used since 2018. I used to run but now only walk at 3 to 3.3 mph on it for about an hour a day. I weigh 185 lbs. I lube the belt once every 2 months. About a week ago I started to smell a very strong burning smell as I approach the one hour of use, and opened up the hood to check it out. I don't really see anything that is obviously burned or melt, and after using the treadmill without the hood, it looks like the smell is coming from the motor. Due to the way it is mounted, I can't really see the inside of the motor to see what is burning. So I am trying to go through the steps to diagnose it and will be getting a clamp meter in a couple days to check the draw. In the mean time is there anything else I need to look at to figure out what is going on? I am hoping that it is something relatively easy or inexpensive to fix as I am not very handy nor knowledgeable in this nor can I throw a lot of money at it.
Also, there is something that looks like a fan on top of what i think is the incline motor-is it supposed to spin when the treadmill is running? I circled it in one of the pictures. I don't see it move at all when I'm using the treadmill.
Thank you so much in advance!
![IMG-20220410-155328577](https://i.postimg.cc/BP0gtP90/IMG-20220410-155328577.jpg)
![IMG-20220410-155447906](https://i.postimg.cc/7fXVYLKF/IMG-20220410-155447906.jpg)
![IMG-20220410-155453796](https://i.postimg.cc/3d31TGFj/IMG-20220410-155453796.jpg)
![IMG-20220410-155502022](https://i.postimg.cc/CdG7X7kL/IMG-20220410-155502022.jpg)
![IMG-20220410-155510706](https://i.postimg.cc/wRQkNxgs/IMG-20220410-155510706.jpg)
![IMG-20220410-155925297-1](https://i.postimg.cc/bDbgzH5g/IMG-20220410-155925297-1.jpg)
DC Amp Draw
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Discount Code - COPY AND PASTE this code, 1982 in the discount code box for a 5% discount off your order,
also what is burning inside the motor? Is the motor permanently damaged once it starts burning? I am afraid that the motor will go downhill from here even with a new belt. thank you again!
No most times the motor is fine- I would not use it until you test the amp draw.
Can you point me to the replacement belt and possibly deck and instruction to change them? Thank you!
My model number is PFTL39715.1
https://www.treadmilldoctor.com/proform-performance-300i-pftl397151-walking-belt-308725
https://www.treadmilldoctor.com/proform-performance-300i-pftl397151-deck-373280
REPLACING WALKING BELT
