Treadmill: Replacing belt, motor control and drive belt
I am replacing the belt, motor control board and drive belt. For the motor control board, the calibration after installation includes letting the treadmill run at top speed. But I can't check the alignment of the belt until I can get the motor control board installed. I am worried the belt will be off center or too loose to run safely at the max speed needed for calibration.
Any advice?
  • Leave the walking belt very loose and just calibrate unit, once unit is calibarted then adjust your walking belt.
    In the futrue if you need any other parts below is a discount code to save 5%.
    Discount Code - COPY AND PASTE this code, 1982 in the discount code box for a 5% discount off your order,
