Treadmill still stops despite installing a new motor
                    Hi everybody,
I just installed a brand new motor and my treadmill still stops when I step on it. I've tried everything from tightening, to loosening the belt. I added lubricant too. I'm at wits end with this treadmill. I own a Freemotion 890 SRS Interactive treadmill. Anybody have any suggestions?
Sincerely, Frank
Sincerely, Frank
When the running belt stops does the Drive Motor also stop?
If the entire front roller continues to spin then you will need to adjusted running belt.
This should help you trouble shoot exactly what is wrong with your treadmill
