Treadmill still stops despite installing a new motor
Hi everybody,
I just installed a brand new motor and my treadmill still stops when I step on it. I've tried everything from tightening, to loosening the belt. I added lubricant too. I'm at wits end with this treadmill. I own a Freemotion 890 SRS Interactive treadmill. Anybody have any suggestions?
Sincerely, Frank
  • Hello and sorry to hear this!
    When the running belt stops does the Drive Motor also stop?
    If the entire front roller continues to spin then you will need to adjusted running belt.
    This should help you trouble shoot exactly what is wrong with your treadmill
  • Thank you! I am going to go through it step by step and report back.
  • So, it was an easy fix. My treadmill is a fold up one, so over the years the lubricant got into the motor belt. I simply took off the motor belt and degreased it and cleaned the motor and roller contacts. The treadmill works fine now; no slippage.
  • Enjoy your treadmill
  • How did you clean this? I have the same issue! Can you recommend a prouct to clean the lubricant off the drive belt and rollers?
  • simple green
