Raised folds developed on my treadmill belt
                    Hi
I recently had the belt on my Bremshey Treadline Pacer adjusted (ie tightened) and it has since developed two raised folds which run the full length of the belt. In addition it has crep way over to the RHS (the gap at the LHS IS 2cm whereas on the RHS it is nearly touching the side). Grateful for ant advice on how to rectify the problem - the belt was slipping prior to it being adjusted and I suspect it has been over tightened.
Regards Treadyb
Regards Treadyb
