Raised folds developed on my treadmill belt
Hi
I recently had the belt on my Bremshey Treadline Pacer adjusted (ie tightened) and it has since developed two raised folds which run the full length of the belt. In addition it has crep way over to the RHS (the gap at the LHS IS 2cm whereas on the RHS it is nearly touching the side). Grateful for ant advice on how to rectify the problem - the belt was slipping prior to it being adjusted and I suspect it has been over tightened.
Regards Treadyb
  • Your belt needs to be replaced, once has developed that raise ridge that cannot be fixed or repaired. To order please call me 888-362-1105 then enter Ext 331 and ask for Jim.
  • Many thanks for your reply. Would you know how much a replacement belt is please. Treadyb
  • GM! This is a special order - please call me 888-362-1105 then enter Ext 331 and ask for Jim :)
