ProForm Pro 2000 Stuck in lowest Decline / Calibration Failed
Brand new, less than 24 hrs out of the box.
Turned it on, declined to lowest position, and now does not raise back up.
Incline calibration fails every time I have tried it, even after multiple power cycles, unplugging plugging back in.
Humming sound when calibration is tried then 'calibration failed'.
Is there anything I can try to fix this issue?
here try this!
https://www.treadmilldoctor.com/incline-calibration-instructions
Thinking about sending this thing back rather than replacing a motor and sensor on a brand new item. Thoughts?
I think you just chanced upon a dud!
At least they are working with you - I have had heard otherwise at times.....
Appreciate hearing more about your experience. Thanks!
