Incline move a little up and down
NordicTrack 3Xi model NTL150085
Incline will move a little up then goes back down
-does the same in calibration mode
-Will not respond to up/down buttons on console
-When first powered up or in calibration mode will only move a little bit
1. Installed new incline sensor [NO GOOD]
2. Installed NEW incline motor [NO GOOD]
3. Control board has RED led on all the time
4. Control board has 2 red leds on while incline moves up the down and then they go off and incline stops
David
David
--When trying to calibrate it says " calibrating" but does not show ----
--Cannot move manual using incline up/down, it does make the beep like it is trying but
no go
-Both red wire and black wire that goes to incline motor both have 120 volts whenever it
is on
-Unplug one side and turn it on it does move but same thing a little ways and then stops, plug in other side and unplug the first one it moves the other way a little bit and then stops
-Took motor off and put 120 volts on it and it runs fine does not shut off until I took
power off, put 120 volts on other terminal and motor goes the other way just fine.
Controller or Console?
