Nordic Track A2350 NTL07007.0
I have had the Nordic Track treadmill A2350 NTL07007 for a long time. Recently while using treadmill it sometimes stops in the middle of a walk. I am assuming 2 things...either the motor is over heating and needs replaced or the belt need lubricant. So the question is what do I do? I think i can try to replace the motor myself but when searching I am having issues with a motor that states my exact model number for treadmill. I have however found the same model numbers of the motor. Will me buying a motor with the same model number as the current motor work even though it does not state that it goes on mg treadmill?
I would lubricate the belt really well before replacing the motor as they can be expensive!
Here is a link for lube - ours is actually formulated to repel dirt:
https://www.treadmilldoctor.com/world-famous-lube
On motors - it just depends as the mounting brackets are in different places even on motors that say they are the same.
Here is a link for the motor that fits all 7 models of the NTL07007:
https://www.treadmilldoctor.com/nordic-track-a2350-model-ntl070076-treadmill-motor
There are a few tests you can run to make sure of your issue before spending a lot of money
cleaning the belt:
https://www.treadmilldoctor.com/why-clean-the-top-of-the-belt-kf
Here are a few things you can look into to see why your running belt is stopping when you walk on the treadmill.
Let’s remove the hood cover on your treadmill.
Now run the treadmill at 2.5mph with no one on it and see how it runs.
Now go ahead and step onto the belt and see what happens.
When the running belt stops does the Drive Motor also stop?
If the entire front roller continues to spin then you will need to adjusted the running belt.
Let us know how we can help!
