Vision Eliptical X61003
Need to get inside the unit. I've removed all the cover screws and the nuts in the center but I cant get the wheels off the side. do I need some kind of puller or is there a trick I'm not seeing. Any help is appreciated.
  • Normally you will need a crank puller which in your case it would a 22mm
