Quiet, iFit on separate TV, under $1500?
My wife and I are light users. We are both under 160 lbs, we run 3 times a week for 30 minutes if we are lucky.
I would like a recommendation for a:
1) Quiet machine (my wife will be sleeping 2 rooms away while I pound on the treadmill)
2) I want iFit to control the speed and slope - but I will be using a wall-mounted TV - not the built-in display.
3) I want to spend under $1,000, but will go to $1500 if needed.
4) Folding
What do you recommend under $1,000, under $1300, and also under $1,500?
4) Folding
It also looks like the Proform Smart Pro 2000 and Smart Pro 5000 are the same machine less screen size and a slight motor size difference. And I do not need a larger screen and a slightly larger motor is not a big deal for me - so the 2000 seems better for me? Are my assumptions correct?
Now, considering that I will not be needing the screen on the machine because I am using an external TV for iFit, do you think I would be better off with the Proform Trainer 8.0 instead of the Smart Pro 2000 because of better build quality?
