Treadmill starts then when I step on it it’s slow and stop
                    I have  a T6.3 NT 5 years old with a new motor and control board
So when I start it it goes then when I step on it within couple minutes it’s slow down gradually to a halt. The controller’s red LED starts blinking at intervals . Any idea ? I have tightened running belt and lubricated it. It’s seem a fold back mode.
Also my Incline does it start when powering up but does not respond to control up or down afterward.
Thanks
Steve
Thanks
Steve
When the running belt stops does the Drive Motor also stop?
If yes then it could be a weak Drive Motor or bad Motor Controller.
If the Drive motor still runs and Drive Belt does not then you will need to tighten down the Drive Belt or replace the Drive Belt.
If the entire front roller continues to spin then you will need to adjusted running belt.
If just the pulley on the front roller continues to spin, then you will need to replace the entire front roller.
This should help you trouble shoot exactly what is wrong with your treadmill
