HORIZON T72 does not run
had it for a couple years, the past month while running, speed would skip then go skip then go. as if it was out of sync.
recently i tried turning it on, and everything works on the panel then it it counts down 3,2,1 and then nothing happens even though the display shows as if everything was working as normal.
i went into engineering mode and tried to run calibration, the error E1 comes up.
a friend suggested speed sensors, i tested the magnetic located on the roller for continuity and it checks out good. I am unable to check the optical sensor thats mounted on top of the motor itself as i have no idea how.
is it possible that the optical speed sensor has gone kapput and its preventing the threadmill motor from running at all.?
if not, what are other options?
