Display Screen Issue-Sunny Treadmill T7515
This week the display screen on my treadmill started fading out about 15 mins into my walk.
I took the cover off as directed on the Sunny website and checked to make certain everything was connected. Everything appeared to be fine. I saw no bent or broken wires. I’ve unplugged the treadmill and plugged it back in several times. I can not find a reset button.
Each time I turn it off and back on the screen appears perfectly but then fades out again.
Please help me solve this issue.
  • it sounds like you made sure all wires are securely plugged in inside
    please not check to make sure there is no crimping in the wires
    (You need to check for volts DC on the black and red wires for the 8-12V.
    if this does not help you can check the magnet/sensor with this link
    https://www.treadmilldoctor.com/panel-dims-kf
