Treadmill problem please help
Hello
Have a Sears free spirit 30517 should be the same as horizon tm-145
Sn= tm189
Runs the belt for three or four revolutions then stops and just beeps until turned off
Have confirmed reed sensor on front pulley of belt is working with correct gap. Replaced the optical speed sensor and the motor control board.
Ran all engenering test and all led and buttons work. Nothing is stuck
Will not calibrate
The belt and the deck are not worn out and all of the above test and calibration is being done unloaded just with the belt and no person on it.
The upper console board has been discontinued and not sure if I could get a used one.
Thanks for reading and help
Sn= tm189
Will not calibrate
It also beeps and locks up after the same amount of time if just turned on and not started.
Also checked wiring from harness in MCB to console plug.all test ok
When calibration starts it reads speed around 406 - 550 then when the belt speeds up it errors and beeps then stops. Also if you just power the treadmill up and let it sit then it starts beeping after 30-45 seconds
35002276
