Proform Crosswalk Fit 415 issue - powers on but nothing else
I have a Proform Crosswalk Fit 415 (Model Number 831.24853.0). The unit does power on - the display beeps once and lights up when the magnetic safety key is applied - but no response when pressing any of the buttons. I do notice that if I place my fingers on the silver "pulse" readers, the display will show the heart rate but none of the other buttons work (incline up/down, start/stop, speed, etc).
I have unplugged/reset, all the ususal stuff with the same result. Looking for suggestions on what to check next.
If it turns out to be the controller board, I also would like to know which part number to use. The controller board is imprinted with MC2100LT REV ICON 2006. There is also a sticker on the side of the transformer mounted to the board which reads MC2100LT-12 226706, and there is a green sticker on the side of the aluminum heatsink which has MC2100LT-12. I tried looking this part up on SearsDirect and got a completely different part number which is 357333, now replaced by 405825.
we have an updated MC-2100 that works better than the original
