Norictrack Elite Xi Will not turn on
Model: NTL11808.0
HI guys!
I have the above mention treadmill, and have had it for 10 years. The thing is a Tanks and i've never had issues with it.
I went to turn it on the other day and when I connected the magnetic "key" nothing happened. I reset the power and noticed the lights flash as they normally do when I turn it on, but still nothing when connecting the key.
After a little research I found that the magnetic switch sometimes needs to be adjusted so i took the top off and removed the board. There was a little corrosion on the switch and magnetic plate that I cleaned off and then resembled the top cover.
The issue remains.
I'd like to replace the board but cannot find the part number anywhere, and its not in the manual. I cant find anything with any of the numbers on the board either.
Any tips or recommendations would be greatly appreciated.
Image: https://ibb.co/g4D7d5B
Thank you!
Wrek
HI guys!
The issue remains.
Thank you!
Wrek
https://www.treadmilldoctor.com/nordic-track-elite-zi-model-ntl118080-motor-control-board
