DRIVE MOTOR OR MOTOR CONTROL BOARD - HORIZON FITNESS
                    We have a Horizon Treadmill - model CST4.5. After a few years of inactivity, we started using it again. When we started it up, there was a slight grinding noise... more noticeable at slower speeds - 4.5mph and lower. There was also some intermittent hesitations. After a few weeks of use, the treadmill died. Do you think the issue is the drive motor or the motor control board?
Thanks.
                            Thanks.
https://www.treadmilldoctor.com/motor-testing
Procedures:
Using a dc volt meter (if non-auto ranging set for the 200vdc range), test the voltage at the red and black motor
leads with the motor still attached.
Note: This should be tested after the console cable and optic sensor points because they can give the same
results as a defective lower board.
Note: A non-functional system may still have a voltage present with no motor attached. For accurate results, the
motor must be attached when the voltage is checked.
Desired Results:
The voltage charts contain typical desired results on a fully functional system. A variance from the norm would
indicate a defective component.
0.5mph
Volatge After Start @ 10.0mph
Across Motor Out,
No Motor
Attached
0.0-22.5 vdc 0.0-22.5 vdc 0.0-22.5 vdc
Across Motor Out,
W/ Motor
Attached
0.0 vdc 2.5- 0 vdc 80-100.0 vdc
