Any Advice? Also how do I align a front and rear roller?
                    I was trying to replace the rear roller and walking belt in my Horizon T101 treadmill. I was able to remove and replace the broken rear roller. However, after taking the deck and front roller the belt doesn't fit.  I even called and gave the model number to the guy.
I essentially have two problems. First I forgot to mark the position of the front roller. I do not know where the front roller goes. I'm tried using a level though to make sure its level. The other problem is the belt I ordered won't fit. The worst part was that I told the guy the model number to get the right walking belt. I'm just frustrated. I watched a video and took apart the deck. Then, I reassembled the deck and put on the front roller. Finally I can barely tighten the screws or even get the screws on for the rear roller. I think I'll put on the old belt unless anyone has any advice before taking it apart again.
I put the old belt which is probably worn out and belt is moving all over now. Any advice? I'm not even sure what to do anymore.
