Nordictrack C2200 slow (constant 1mph with no weight)
Hi,
This is my first post. I have a Nordictrack C2200 that is slow. No matter the speed setting the motor turns at that same rate (there is no visual or auditory clues that the unit is increasing speed). when I step on the platform and set a speed the belt does not turn (but I do not hear the motor turning).
Do you have any ideas?
thanks
thanks
Here are a few things you can look into to see why your running belt is stopping when you walk on treadmill.
• Let’s remove the hood cover on your treadmill.
• Now run the treadmill at 2.5mph with no one on it and see how it runs.
• Now go ahead and step onto the belt and see what happens.
A) When the running belt stops does the Drive Motor also stop?
A) If the Drive motor still runs and Drive Belt does not then you will need to tighten down the Drive Belt or replace the Drive Belt.
A) If the entire front roller continues to spin then you will need to adjusted running belt.
This should help you trouble shoot exactly what is wrong with your treadmill, and remember to lube your Running Belt & Deck every 6 months.
https://www.treadmilldoctor.com/walking-belt-lube-instructions
