NordicTrack C2300 restarting incessantly
                    I have a slightly used NorticTrack C2300 that suddenly after sitting in the house idle will not start properly.  The lights come one but the treadmill restarts after two seconds and continues restarting again and again.  I've tried several outlets near and far that all check out with an outlet tester.  After attaching the red key, if I press start during startup the tread moves for about two seconds and then shutdown with the perpetual restart.  If I press the fan button it will run for a couple of seconds similarly.  Thank you in advance for sharing any direct knowledge of the problem.  I'm hopeful that I can avoid a trial and error approach to the solution.  I made a video of the rebooting display on Youtube,
