Treadmills shutting down during use
One of the biggest problems customers will have with treadmills is they will shut down during use. The most common problem is the lack of lubrication between the belt & deck on your treadmill. Without the proper lube the belt & deck will build up friction ,which is heat that is transfer to the treadmill lower electronics and drive motor which will cause them to overheat and shut down.Over time if the belt & deck is not properly maintain it could cause damage to the lower board or even the motor. Below is a link on how to lube your deck & belt and also a link to what type of lube to use.
http://www.treadmilldoctor.com/walking-belt-lube-instructions
http://www.treadmilldoctor.com/lubricants-cleaners-12
