Pro Form T4 - Will not power on
I moved from one room to another where it worked fine a few months ago. Tried to turn it on once moved, the display will not power on with key. I tried to reset and nothing. Any ideas?
  • I would check the wire connections to console and to motor controller, take the hood off down below and see if you have a lights lite. Also is your outlet controlled by a switch?
