NordicTrack EXP 1000 slips
I recently replaced the belt forum.treadmilldoctor.com/discussion/1588/nordictrack-exp-1000-replacement-belt#latest, lubed per instructions and now the belt slips. If I tighten the belt enough to stop the slipping, the belt stops/slows down drastically.
The "white line" test is OK, and the drive belt appears to be fine. The motor does seem to run quite hot, enough so that you can feel it through the hood. The motor controller was replaced several years ago.
Any other suggestions?
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
