Nordic Track XT 1500 - Belt gets stuck on the platform
My belt gets stuck on the platform as I walk.
I have tried lubricating underneath the belt between belt and the platform - DID NOT HELP
I have also tightened the belt - DID NOT HELP
Can you please please help me solve this.
MY RUNNING BELT STOPS WHEN I STEP ON IT
Here are a few things you can look into to see why your running belt is stopping when you walk on treadmill.
• Let’s remove the hood cover on your treadmill.
• Now run the treadmill at 2.5mph with no one on it and see how it runs.
• Now go ahead and step onto the belt and see what happens.
A) When the running belt stops does the Drive Motor also stop? NO
A) If the Drive motor still runs and Drive Belt does not then you will need to tighten down the Drive Belt or replace the Drive Belt. NO
3rd When the running belt stops and Drive Motor & Drive Belt continues to spin does the entire front roller rotate? NO
A) If the entire front roller continues to spin then you will need to adjust running belt.
This should help you trouble shoot exactly what is wrong with your treadmill, and remember to lube your Running Belt & Deck every 6 months.
From above, it looks like I have to change the entire front roller. Any word on changing the drive belt or pulley?
