ProForm 680 LT belt not moving
I have a ProForm 680LT and the belt doesn't move. I went through the diagnostics and I tested the motor with a 12 volt battery and the motor does spin. The display works and goes through all of the tests. I just wanted to verify that I need to replace the Motor control board or is there something else that i should check before replacing the board.
