Precor M9.45i
Having an issue where the speed up button does not work, or works very infrequently. Incline/decline and speed down work just fine.
  • It almost seems like the button is "sticky" or stuck pressed.
  • Button maybe is worn out, you may need to replace keypad if available still. what is the serial off unit?
  • Hmm I’m not seeing a s/n. Might need to take the cover off. I do see a full replacement console on ebay that would probably do the trick. I haven’t seen just the keypad anywhere
