NordicTrack Commercial 2950 issue
Hello,
Our NordicTrack Commercial 2950 treadmill (model# NTL19119.0) is acting up. The belt will start up and work as it should, but then the speed will decrease/drop, often times coming to a complete stop, then start back up to the set speed, then shut down for a random amount out time, then start back up again. The issues have been somewhat random...the previous week we had the issues noted above, so I lubed the belt - then we both ran 4 mile runs on it over the weekend with no issues - then on Monday my wife got 1.5 miles into a run and the issues reoccurred. At this point we've deemed it unsafe to run on due to the immediate decrease in speed while running.
I took the motor cover off and the issues are reoccurring with no one on the belt. I watched the red LED light and I see a 'one blink' light which NordicTrack says the unit is going into 'fold-back mode'. However, the belt will stop, or slow down to about 1MPH, then start back up again to the set speed and then red LED light goes to a steady blinking when the belt starts back up to the set speed.
A bit of info on the machine: We got in 2016 or maybe 2017. We've had the deck replaced three (3) times after they cracked (covered by NordicTrack). No other issues with it. We have just under 800 miles on the machine - we use it mostly in the summer months due to heat and our 3 kids schedules (we live in Texas) - when we do use it we work it pretty hard. The belt has never been replaced, but it shows no discoloration or major wear, I've kept it lubricated. The belt moves easily when off so I don't think the motor is seized.
Based on other folks issues I am trying to decide if I've got a controller board issue, or a belt issue, or both...or something else??? Any help would be most appreciated!
