Pacemaster pro-plus
Hi. I have a Pacemaster pro-plus. I’ve had it in storage. I put it back together. When I put the safety key in, the treadmill turns on, flashes L6 in the distance window. When I press start the treadmill increases the speed. The stop button doesn’t work, neither does the faster/slower button. Is this a memory board issue? Thoughts?
Once you've added items to your Cart, and you are ready to Check out and you put all your shipping info in. Use this code 1982 at checkout for a discount on your order.
