NordicTrack 2950
Hi folks,
Anyone know where I can get a wiring diagram for the NordicTrack2950 and/or info on how I get to the underside of the horizontal panel with the buttons ... the underside seems to be one panel with the grip bar but (as I didn't install it) I don't know exactly how it comes apart. I am OK to just go with the 'unscrew everything and see' method but thought I would check if anyone has info on this first.
I am looking to hack the incline and speed buttons via an external controller which I am hoping is a matter of jumping the switch and lining that out to a controller board - could be an interesting project which I will be happy to share if/when I get it completed :-)
Any help appreciated
It looks like the panel below the buttons separates but not sure the sequence of disassembly and whether the pulse bar will wiggle out of the side supports. Any help very much appreciated.
Could I not put a 'short' wire over the button (effectively completing the switch), controlled from a momentary switch? This switch activation would be via a relay/switch interface from a Raspberry Pi or similar on signal from the software.
Apologies if I am not getting the way the wiring works on this :-)
