Smooth 6.25
Bought 2009 .In 2012 had a issue where it would not run . They sent some diagrams and we determined it was a pinched wire from the console to Motor Control . rerouted wire and has bene trouble free until 2 weeks ago. it shut off at 38 minutes . Smelled like something hot which refreshed my 2012 issue. I waited 5 min and it ran well . I took off shroud and cleaned everything and it ran well next two weeks. put shroud on and it ran for another week .Sunday it stopped again around the 34 min mark and again some smell . Waited about a hour and it started but only ran 8 min .Will not run now . I had a spare motor and ran wires to it-NO LUCK. Replaced the pinch wire from way back in 2012 -NO LUCK . Console lights up and appears to work ok . Elevation motor works . The reset switch on side has no resistance when you push it but since have power on everything assume its ok ? Belt seams ok . Looking for ideas ? thinking it might be a bad Motor Control Board and have a electrical guy coming to help . Really need to get it going as having some issue with health and need this as walking outside in Pennsylvania in winter is bad. If cant fix will need top buy another one quickly - any recommendations . Age 74 -only walk on it . Have really never used programs or even elevation .Just basically walking .Any place to get poarts for Smooth
https://www.treadmilldoctor.com/dc-amp-draw
