Sole F63 gettin no display and not functional' LED is on at main control board so getting power to u
Sole F63 was prepped for transport from one local district to another here in Alexandria,Va. Th3 Console was disconnected from the main section of treadmil by unscrewing bolts and disconnecting 3 connectors. Two are 3 pin connectors and the third is a white 6 pin connector. I noticed that the wire on on of the pins of 6 pin connecter is separated from pin so it wil need to be respliced or connected. Notsure if that will solve problem but was working prior to disconnection for transport. Can someone recommend a local treadmill repair service for Alexandria,Va. for the Sole F63 treadmill. Your help would be greatly appreciated. Frank
