Foam Pad Under Belt for ProForm 740CS
I have an old ProForm 740CS. In between the belt and the top of the deck there is a thin sheet of low-friction plastic and a 4 mm thick piece of foam. Both are about the size of the deck. The foam is compressed so there are slight valleys where my feet usually land. I would like to replace the foam.
I looked at the exploded drawing, but there is no part number for this foam, or the thin sheet of plastic. Based on pictures of the deck, the foam and plastic are not part of that, but I could be wrong.
Can anyone give me a part number, or someplace to call?
Is the foam actually part of a deck assembly?
and
Here is a code you can use on the checkout page for a 5% discount (5offkevin)
