problems with NT C2200
My problem is when I put the safety key in the digital display lights up,( normal) when push the start button the MPH indicator reads 1 mph,(normal) the motor and belt starts to turn on, and quickly shuts off.(not normal).
the incline mechanism works normally all the other digital readout functions work normally.
any suggestions.
Rider
Here is a code you can use on the checkout page for a 5% discount (5offkevin)
Where can I buy a motor controller went to e replacement parts they have it listed as Obsolete.
Controller Obsolete - Not Available
Part Number:248187
we have these.
the new board only has one yellow ground wire connected to the aluminum plate. Do i run a ground wire from the aluminum plate ground screw to the steel frame ground screw of the treadmill??
