Cybex 900 Treadmill incline/decline issue
After a limit switch got stuck, the treadmill declined all the way down until the chain on the incline/decline mechanism broke. I disassembled everything, repaired the chain, cleaned and tested both switches.
On startup, the I/D motor moves a bit and the optical sensor spins approximately 1 revolution and then stops. There is a -- on the dispay for I/D.
The treadmill operates fine other than that. I am getting errors 12 and 13 even after clearing the codes.
Is there a calibration sequence for this model? Can someone give me an overview about how the switches and optical sensor work together?
I have not tried removing the motor to ensure it is not stuck, so that is something I can try.
Any help would be appreciated.
Debug Trace
| Notice |
Cannot assign an empty string to a string offset
#0 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(1883): gdn_ErrorHandler(2, 'Cannot assign a...', '/home/fitplusws...', 1883, Array)
#1 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(1219): Gdn_Format::formatMentionsCallback('')
#2 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(1966): Gdn_Format::tagContent('@KevinC, how do...', 'Gdn_Format::for...')
#3 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(1848): Gdn_Format::mentions('@KevinC, how do...')
#4 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(878): Gdn_Format::processHTML('@KevinC, how do...')
#5 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.format.php(2198): Gdn_Format::html('@KevinC, how do...')
#6 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/views/discussion/helper_functions.php(24): Gdn_Format::to('@KevinC, how do...', 'Html')
#7 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/views/discussion/helper_functions.php(164): formatBody(Object(stdClass))
#8 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/views/discussion/comments.php(19): writeComment(Object(stdClass), Object(DiscussionController), Object(Gdn_Session), 6)
#9 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/views/discussion/index.php(53): include('/home/fitplusws...')
#10 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.controller.php(718): include('/home/fitplusws...')
#11 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.controller.php(1316): Gdn_Controller->fetchView('', false, false)
#12 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.pluggable.php(210): Gdn_Controller->xRender()
#13 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/applications/vanilla/controllers/class.discussioncontroller.php(279): Gdn_Pluggable->__call('render', Array)
#14 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.dispatcher.php(845): DiscussionController->index('10174', 'cybex-900-tread...', '')
#15 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/library/core/class.dispatcher.php(274): Gdn_Dispatcher->dispatchController(Object(Gdn_Request), Array)
#16 /home/fitpluswsos/domains/forum.treadmilldoctor.com/public/index.php(29): Gdn_Dispatcher->dispatch()
#17 {main} |
