Preform 725 Stops intermittently during walk
Will walk for a good while 20 minutes or more. This is not a consistent time but almost always over 10 minutes. The treadmill will stop running. Can restart the treadmill right away or wait a minute and continue walking. It will stop again but in less time. Suggestion on how to fix it?
  • Sounds like the electroncis are overheating , could be cause by a worn walking belt. I would try to lube walking belt and see if that helps, if not you may have to replace walkig belt. LUBE DECK
    Discount Code - COPY AND PASTE this code, 1982 in the discount code box for a 5% discount off your order,
