Sole F63 Speed Problem
My wife has an F63 she walks on at 3.4mph. She recently complained it was running too fast and when I checked it was going at a running speed, way more than 3.4mph. The belt is lubed, I opened it and there was hardly any dust. No error messages. I did a calibration a few times and it finally slowed down but she claims it's now running slower than it did.
Any ideas?
Thanks
  • 1) Remove the safety key
    2) Press and hold down the Start and Fast (speed up) buttons with one hand and
    replace the safety key with the other. Continue to hold the Start and Fast key until
    the window displays “Factory settings”, then press the enter key.
    3) You will now be able to set the display to show Metric or English settings. To do this
    press the up or down key to show which you want, then press enter.
    4) Make sure the wheel size diameter is 2.00 then press enter
    5) Adjust the minimum speed (if needed) to 0.5 and then press enter
    6) Adjust the maximum speed (if needed) to 12.0 and then press enter
    7) Adjust the maximum elevation (if needed) to 15 and then press enter
    8) Grade return – On (This allows the incline to return to zero when stop is pressed. For
    sale in Europe, EU standards require this to be off)
    9) Press start to begin calibration. The process is automatic; the speed will start up
    without warning so do not stand on the belt.
