Nordictrack C2200 Treadmill - Walking belt and motor stopping
My treadmill is about 15 years old and has not been used a lot. But has been a good treadmill.
The last several months I have been just walking on it 3.2 mph for about 45 minutes. Noticed about a month ago, about 30 minutes into a 45 minute walk I would get a random clicking noise. Could not figure out the source as it was random.
During other trouble-shooing I realized I had not lubed the walking belt recently. So purchased 100% silicon and lubed the walking belt. However, that made no difference on the random clicking noise.
The motor / controller cover has been removed for trouble-shooting.
In the last few days...about 2 minutes into a walk, all of a sudden the walking belt stopped. I stepped off the belt and it slowly started back up again and got up to speed. I started walking again and the belt stopped right away again. I noticed the motor pully and the drive belt stopped when the walking belt stopped.
I did lube the walking belt again, but that did not make a difference on the belt stopping. I did look under the belt at the top of the deck and did not see any wood showing, just the normal black deck surface.
I took the motor off and took it to a local, trusted, electric shop. They checked it over and said all is good on the motor.
What is my next step in trouble-shooting my walking belt stopping?
Thanks,
Kevin
Thanks,
Kevin
I have tested my motor with a DC battery, and the motor runs. I have changed my motor belt for a new one. I have calibrated the treadmill speed using the potentiometer to 16.0 kmh (10mph). I have lubricated the belt ( I've just put almost 2oz of lubricant). I have tried to loosen the belt until it slip...and tighten it just a little bit. I've connected the treadmill on a 20 amp...and nothing changed.
My motor pulley and the drive belt stopped too when the walking belt stopped...
I'm just wondering if it's just the motor that's is getting weak..
also:
When the running belt stops and Drive Motor & Drive Belt continues to spin does the entire front roller rotate?
Have you reached any conclusion? I have a very similar problem.
Many thanks
Do you think the problem may be the walking belt? I've take a picture of the underside of it.
https://www.dropbox.com/s/nskuze5e11pstmt/144065244_222866849476108_3986779084241076024_n.jpg?dl=0
When the walking belt stops on mine the drive belt stops and so does the motor and thus the front roller stops as well.
I will check the power from the controller board to the motor this weekend, looking for the 8-12v to power the motor.
Thanks,
Many Thanks
Just got the motor mounted back on the treadmill.
I put my volt meter on the black and red wire connectors on the logic board. Had my wife change speeds on the treadmill while I watch my volt meter. Checking for V DC... at the slower speeds (2-3 mph) and had less than 5 VDC going through. When I had her change the speed to 7 mph, I got 12 VDC.
Played with the speeds some while watching the voltage. Definitely saw less than 8 VDC on speeds of 5 mph or less.
So....bad logic board?
Thanks,
Kevin
Thanks,
Kevin
I tried a walking test at 2.4 mph. I was okay for 3-5 seconds then the treadmill started to slow down, then it stopped. I stepped off and it slowly started up again....it ran itself up to 3.6 mph before coming back down to 2.4 mph on its own.
I repeated this test at 3.2 mph with similar results.
I did also watch the red LED on the controller board. When first plugging the power into the wall I got a solid red light. When starting the treadmill at the 2.4 mph I got a fast blinking light. When the walking belt, drive belt and motor stopped I had a slow single blink about every one second or so. Once turning off the treadmill everything seemed to reset and go back to normal for the light.
I also noticed the white block that sticks out on the controller board was so HOT I could not touch it. I will attempt to include a picture of that while block on the control board with a red circle around it in the picture.
Won't let me save the link for the picture.
