Too Much Silicone Lube????
I was given a Nordic Track 1000x. I worked fine.. Needed cleaning an maintenance if figured. I didn't have a manual.. I assumed, according to YouTube, I was supposed to lube the belt. So I got some Treadmill Doc silicone lube. I downloaded a manual and much to my dismay I wasn't supposed to lube the belt.... The belt didn't slip before I lubed it, but it does now.....ahhhhhhh
Now what..
Now what..
https://www.treadmilldoctor.com/treadmill-doctor-treadmill-belt-cleaner
and a little light reading:
https://www.treadmilldoctor.com/keys-manual-says-to-use-only-lubenwalk-or-not-to-lube-kf
MY RUNNING BELT STOPS WHEN I STEP ON IT
