Too Much Silicone Lube????
I was given a Nordic Track 1000x. I worked fine.. Needed cleaning an maintenance if figured. I didn't have a manual.. I assumed, according to YouTube, I was supposed to lube the belt. So I got some Treadmill Doc silicone lube. I downloaded a manual and much to my dismay I wasn't supposed to lube the belt.... The belt didn't slip before I lubed it, but it does now.....ahhhhhhh
Now what..
  • This cleaner came last yesterday. I hope to try it today..... I hope I do not have to remove the belt to get it clean enough.. that looks like a pain! Thanks for your input....I will repost after I clean the belt and rollers..
  • IT DIDNT WORK... NOW WHAT?? HELP
  • May not be the belt that is slipping.
    MY RUNNING BELT STOPS WHEN I STEP ON IT
    B) If yes then it could be a weak Drive Motor or bad Motor Controller.
    B) If just the pulley on the front roller continues to spin, then you will need to replace the entire front roller.
  • Hello,
    My DRIVE belt is slipping. It noticed upon inspection covered in lubricant.
    I assume since it is meant to pull it sould be clean and dry? Or does it need to have lubricant on it? The motor spins but the drivebelt slips when standing on the deck.
    If the lubricant needs cleaning off what is a safe cleaner to use - I assume it is the silicon oil frm the deck that has somehow got onto the drive belt.
    I do not want to corrode any parts of the treadmill and make mattrs worse!
    Thank you!
  • try using a dry rag and wipe it off or try simple green and a rag and clean off belt
