Lubed belt a few months ago belt has been stalling since
Hi,
I lubed my treadmill belt about 6 months ago and the belt has been sticking with each step ever since. I'm 100% sure the belt had never been lubed before that point and whatever lube was on there was just the lube that was left over from the factory. I used a silicon based lubricant which from the impression I'm getting from the treadmill community, was a bad idea. I followed some YouTube videos and tightened and centered the belt. It still stalls and I can stop it by putting a foot down on the deck.
Did I ruin the belt?
Here is a link to the lube I used.
https://www.amazon.com/Lube-N-Walk-TL54-Treadmill-Lubrication-Kit/dp/B000VZLCWY/
  • When belt stops, does motor & drive belt and front roller still spin?
  • MY RUNNING BELT STOPS WHEN I STEP ON IT
    B) If yes then it could be a weak Drive Motor or bad Motor Controller.
    B) If just the pulley on the front roller continues to spin, then you will need to replace the entire front roller.
