Kettler I-Run E7
Hi there yet another problem with a treadmill!
I have a Kettler i-run with an E-7 message on the console. I've just had the control board fixed after a DC-6 error it had previously. Now it will run for a few seconds and stop to display a E-7 message which after a little research seems to point to a bad incline motor. I have had the motor off the machine and tested it and the shaft spins but doesn't go up or down. Is this a case of a bad incline motor or is there anything else I can check or test to work out what exactly is wrong with it? Or is the error something else?
