Pacemaster ProSelect Error Code 9
When I turn on via the magnet, treadmill gives an Error Code 9, but I don't know what that means. Any advice?
Thank you in advance.
  • Err Code 01 through 18 - (Button Error) Indicates the keyboard membrane has a stuck key. Do not hold down any key for more than 5 seconds or this error will appear.
    1. Insert the magnetic key back into the control panel and do not touch any keys, if the error occurs, replace the keyboard membrane.
    2. In very rare cases, a defective upper circuit board can cause this error and the circuit board will need to be replaced.
  • Thank you. That gets me started. With the company having stopped supporting Pacemaster, I was wondering if I would be able to make use of a Pacemaster ProElite Control Panel assembly on my ProSelect. It seems that there are many similarities between the two? Only main difference I can see is that Pro Elite uses a higher horsepower motor.
  • You would have to change console & overlay if your going to do that.
