Error code ERR 1
Treadmill was lef on for several days while we were out of town. When I turned unit off and turned it back on today, unit will not run and ERR 1 apparently signals type of problem that is associated with unit failure to run. Manuel does not discuss errors. Please help me.
  • Treadmill is Pacemaster Proselect/ProElite
  • Err Code 01 through 18 - (Button Error) Indicates the keyboard membrane has a stuck key. Do not hold down any key for more than 5 seconds or this error will appear.
    1. Insert the magnetic key back into the control panel and do not touch any keys, if the error occurs, replace the keyboard membrane.
    2. In very rare cases, a defective upper circuit board can cause this error and the circuit board will need to be replaced.
